Read the specs on the Walmart battery before buying it. Just because it's type 27 doesn't mean that it has the same specs as Interstate or Exide. I have a ham radio repeater system that uses a battery for backup when commercial power is down. I originally had an Exide type 27 from Tractor Supply. The dumb charger dried all of the water out of the battery so I replaced it with a Walmart type 27. The battery was cheaper and lighter (less lead) and doesn't last as long as the Exide. When this one fails I will go back to Exide or Interstate.
