- OaklevelExplorerVIN May be stamped near the pin box.
- PhoneDude_8289ExplorerIf there are no stickers or plates with the vin numbers they are more than likely stamped into the metal on the hitch area on or close to the frame.
- n7bsnExplorerPre 1980? Before VIN's where standardized maybe.
In that case none of the above apply. - jimmy_O_ExplorerThe only numbers I can find anywhere on this camper is rite next to the main door. Its an older camper by the way. Numbers are....3822807.....any ideas?
- LOFAT36ExplorerMine is on the left side by the furnace vent's.
- AllworthExplorer IIIf the unit is financed, the VIN will be on the original loan documents. It may just be called "security".
- n7bsnExplorer
jimmy O. wrote:
Ok....where is the v.I.n. located? Thanx
The builders tag, the manufacturers sticker and in most states the registration, of course also the title. - john_betExplorer II
rrbowman wrote:
This is true unless it is real faded like it was on our used mid '90's TT. My 10+ year old 5er's label is begining to fade.jimmy O. wrote:
Is there a way to find out what year a camper is without a title? Any info would help. Thanx! (Model is a sprinter fifth wheel)
Check on the outside left front corner, there is a plate that gives pertinent info along with the date unit was manufactured. - rrbowmanExplorer
Check on the outside left front corner, there is a plate that gives pertinent info along with the date unit was manufactured. - jimmy_O_ExplorerOk....where is the v.I.n. located? Thanx
About Fifth Wheel Group
19,039 PostsLatest Activity: Jan 28, 2022
