RLGetman's avatar
RLGetman
How to remove ZEP Floor Sealer
At first I loved the ZEP floor sealer. Easy to apply & looked great! I was very careful to pre clean my RV with "Bar Keeper's Friend", remove any remaining dust and applied thin coats of ZEP allowing each to dry. The shine was great and has lasted more than a year. I have applied UV protectant multiple times each year.
Recently, the ZEP coating on my end cap and drivers side has begun the crystalize and come off. Looks pretty bad.
What is the best/fastest way to remove the ZEP coating and try another method of revitalization?
I am using a "Cyclo" buffer with their orange cutting pad and a 1000 grit compound called "Renewzit" which also leaves behind a new sealant coat. However, it takes at least two passes to get the surface cleaned off and resealed. Its a lot of work, but seems to be working.
Any ideas on easier/faster removal of the floor sealer?
Thanks!
