RoyF's avatar
RoyF
How to repaint fifth-wheel hitch plate?
Some paint has come off of my hitch plate, leaving a few square inches of exposed metal. My dealer didn't know what kind of paint would hold up. Has anyone tried to repaint their hitch plate, what kind of paint did you use, and did it hold up (or not)?
  • I need to tear mine apart and clean the jaw areas out. Is this possible before painting?
  • I have a B&W. Havent had to worry about the paint coming off yet.
  • Iv'e been using Rustoleum HI-TEMP (BBQ) paint from HD; It seems to have a high percentage of solid and is tough. I've used this on the A-frame of my TTp It has help up well;
    Last year I covered it with Rustoleum Anti-chip/textured paint; This seems to be really tough and has grit in the paint; So far - so good;
    All come in aerosol; Obviously preparation is key to good adhesion
  • I bought the cheapest gloss black paint I could find. Cleaned up the hitch, lightly sanded it then painted it. I then contacted Cequent and requested new decals for the hitch. I did all this last month.
    I also painted the edge of the jaws white. Much easier to see if they are latched.
    Also if you use a nylon disk on the pin you shouldn't get but minimal paint coming off on the hitch plate.
    This is the results.
  • I use Rustoleum Professional Grade gloss black in the spray can. When the warning and capacity labels on the hitch get faded or unreadable, I just send a letter off to Cequent requesting replacements. They send a new set for free.
  • A can of spray paint is cheap even if you have to repaint every year. Can will last several years. Hitch probably was powder coated.
