Bob_Olallawa
Jun 06, 2015Explorer
If you only plan on a BBQ, after the regulator would be the easiest. A lot harder to tap into the system before the regulator and have to run lines to the location you want, but you would be set up for using any propane stuff. A good propane supply outfit should carry everything you would need.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
