D_E_Bishop
Jun 06, 2015Explorer
My rig came from the factory with the tap in place, it is connected between the stop valve and the regulator. In my opinion it is installed in the best place. I do not have to alter any of my appliances in order to connect them to the gas line. My lantern can be hooked up directly to the tap as can the BBQ and the portable stove top. The tap I have is a factory made unit but making one is easy and probably cheaper than buying the fittings.
My rig does not have any flexible line or rubber hose so installing a "T" would require some extensive work. If your trailer has a rubber hose from the regulator to the manifold it is easy but I would still place it between the valve and the regulator.
There are several manufacturers of camping "T"s. Camco, MEC, MB Sturgis. They run $50 to over $100 depending on what you buy. Check with your local RV parts house or propane dealer. If anyone mentions Extend A Stay, they sold out to MB Sturgis and are called Sturgis Stay or something like that.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
