pianotuna
Feb 18, 2014Nomad III
Hi,
Enclosed heated tanks are a good indicator.
Mine are enclosed but not heated. I added a 120 volt outlet and a small heater that is controlled by a mechanical thermostat--so I know I am "good" to -34 c.
Dual pane windows and no slides are also definitely "on the list", as is a heated basement.
Mine has an insulated basement but no way to heat it. I've gotten around that by using "magic carpets" which are heated and radiate down into the floor cavity at 47 C. The end result is that areas of the floor that used to be below freezing are now quite comfortable.
Temperature monitoring is a good thing to add, too.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 20, 2026
