sgolembiewski09
Aug 27, 2019Explorer
Probably not, but close! There might be a slight noticeable difference between the ground water and hot water heater water...
Do I need to be careful when using the pressure relief valve?
2oldman wrote:time2roll wrote:Alternately you can use the pressure relief valve at the top of the WH to expel air.
Connect water to the RV inlet. Run the hot water at the sink until no more air comes out.sgolembiewski0903 wrote:Lol.. it ain't that hot!..is it??
ive in Phoenix, AZ... so the water is already really hot,.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
