- pianotunaNomad IIIdmark67 remove all power to the furnace. Wait ten minutes. Pray to the propane gods and restore power.
- dmark67ExplorerHint:
Propane water heater and stove are working. I took the outside cover off the furnance and there is a circuit board with a red light blinking. Did the reset, no luck. All of my manuals say contact the dealer lol.
Ideas? - Boon_DockerExplorer III
Old-Biscuit wrote:
schlep1967 wrote:
Both run off 12 volt. Is the battery charged and the battery cut-off switch turned on?
This^^^^
Propane is common but stove OK then DC Voltage is the other common component
***first time trying furnace/water in awhile......then could be propane flow
Might have to try each appliances several times to establish full flow/pressure at each one
That was more than likely the problem. - dmark67ExplorerIt's cold, from 0-10 degrees. I waited several hours and now it works...
On shore power and not DC, no problem with anything else (TV, microwave, etc.).
Got to hot in the middle of the night? - Old-BiscuitExplorer III
This^^^^
Might have to try each appliances several times to establish full flow/pressure at each one - pianotunaNomad IIIHi dmark67,
Welcome to the forums.
May I ask how cold it is outside? - Both run off 12 volt. Is the battery charged and the battery cut-off switch turned on?
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
