- rmalik1Explorerstill waiting for KZ to respond.
- alboyExplorerAS per Mbrower ,our newmar is constructed with luan backer glued to the studs 16 inches on center,easy to repair.
- mbrowerExplorer II
goducks10 wrote:
Unless the cutaway is wrong then it looks like the Stoneridge is laminated as it shows Luan backer.
The fiberglass skin will be laminated with a Luan backer but is still attached to the studs with adhesive. The fiberglass skin is very thin and would probably crack in time without the additional support.
With hung walls, the aluminum frame is 16 inch on center and provides the structural strength to the walls. - goducks10ExplorerUnless the cutaway is wrong then it looks like the Stoneridge is laminated as it shows Luan backer.
- rmalik1Explorer
mbrower wrote:
My KZ montego bay is hung wall constructed. I believe their new Stoneridge is hung wall also. I also believe primetime Sanibel fifth wheel is hung wall
Email back from Prime Time Sanibel made with laminated sidewalls.
waiting for KZ StoneRidge rmalik1 wrote:
emails out to KZ for StoneRidge and to Prime time for Sanibel (sp).
My 2008 KZ Montego Bay has hung walls. . . And I believe that the 2015 Stoneridge also has them...- rmalik1Exploreremails out to KZ for StoneRidge and to Prime time for Sanibel (sp).
- rmalik1Explorer
rmalik1 wrote:
azjeffh wrote:
rmalik1 wrote:
rmalik1 wrote:
filrupmark wrote:
Augusta RV does use hung halls. I own a Augusta Flex AF34RS and it does have hung walls. Luxe as well. You can call the factory 574-848-0200 they will be more than happy to answer any questions.
Why would they have a no delam warranty? As hung walls can't delam.
Got a email to the company; will see what they say.
Actually I hope they do use a hung wall as I need another company that may fit into my future plans.
This link is pretty clear on the type of wall used. Select a model for the wall info.....
Welded Construction
16" On Center Hung Aluminum Walls – 3.25 Thick
Got email back from company and they said they use hung walls I did ask for explanation as to why they would have a warranty on something that can't happen. Will wait for that reply! Maybe I missed something.
Ryan Miller(seems to be a straight shooter) from Augusta explained that the term "Delamination" is not used for the the sidewall coming apart but the sidewall coming off the studs. Reasonable explanation but not what most know as Delam. - rmalik1Explorer
rmalik1 wrote:
rmalik1 wrote:
rmalik1 wrote:
Which fifth wheels are built having Hung Walls?
1) Cedar Creek
2)
3)
4) etc
so we have;
1)DRV
2)Lifestyle
3)Cedar Creek
4)Shasta
5)Augusta RV"so far" - rmalik1Explorer
Welded Construction
About Fifth Wheel Group
19,027 PostsLatest Activity: Nov 07, 2025
