- larry_barnhartExplorerI know of 2 wall hung rv's that the walls because very loose. Nothing is perfect.
chevman - DaYooperExplorerMy Shasta Phoenix has hung walls. The wall for the kitchen entertainment slide became detached. I took it back to the factory for repair this past winter and saw the newer models being put together in the factory which was interesting.
- rmalik1Explorer
dblr wrote:
Traveler II wrote:
The old Carriage Line were built that way.
I was told the New Carriage is also a hung wall, but not sure on that.
went to Crossroads web site - laminated also - rmalik1Explorer
rmalik1 wrote:
Which fifth wheels are built having Hung Walls?
1) Cedar Creek
2)
3)
4) etc
so we have;
1)DRV
2)Lifestyle
3)Cedar Creek "so far" - rmalik1Explorer
dblr wrote:
I also think the new Luxe is a hung wall.
Nope it has a 5yr delam guarantee - not hung wall - goducks10Explorer
Looking at the construction cut-away on the Carriage site, it looks like Luan is behind the outer skin. Hung walls don't have that Luan backer. I'm thinking it's a regular laminated wall. Plus they don't mention if the aluminum framing is 16" OC or not. It would need to be at least 16" OC for a hung wall.
Crossroads shows the same construction cut-away for the Cameo, Carriage and Rushmore. - dblrExplorer
I was told the New Carriage is also a hung wall, but not sure on that. - Traveler_IIExplorerThe old Carriage Line were built that way.
- ckwizard777ExplorerHung wals are glued directly to the frame with no lamination in the process, Its a bit more labor intensive vs laminated walls but in my mind a prefered construction method simply because the chance of delamination is reduced and the cost of repairing would be less.
- rtateExplorerWhat is a hung wall?
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 18, 2026
