Mile High wrote:
john&bet wrote:
Duck wrote:
Need to find out what caused the fluid to leak out also.
Don
Fluid level needs to be checked with all slides retracted and landing gear up. Now that he has added fluid with those extended it will probable overflow when they are in and up. Extended hyd. cylinders have more volume than retracted ones do thus fluid level goes down in tank.
X2 You better draw off that extra fluid you put in there or when you do get the ELECTRICAL problem with the motor fixed you are going to have a mess.
I bought 2 quarts of ATF and a turkey baster. Guess what the turkey baster is for? :D
