john&bet wrote:
laknox wrote:
john&bet wrote:
Duck wrote:
Need to find out what caused the fluid to leak out also.
Don
Fluid level needs to be checked with all slides retracted and landing gear up. Now that he has added fluid with those extended it will probable overflow when they are in and up. Extended hyd. cylinders have more volume than retracted ones do thus fluid level goes down in tank.
Level =shouldn't= change much, since oil's filling the other side of the cylinder as it moves, either in or out. In my experience, the main things that change oil level are temperature (oil will expand a bit), leaks (obvious) and air being sucked in somewhere (usually an extreme low oil situation) and causing foaming.
Lyle
Well, I guess you have not spent much time around hyd. systems. I have spent over 40 years around them on the farm and on aircraft. The piston rod takes up considerable amount of space in the cylinder bore.
Well, I was a 4th generation farmer and farmed with my dad until 2000, so I'm not unfamiliar with hydros. All the ones I worked with on a regular basis had hoses on each end of the cylinder. Piston volume had nothing to do with anything, once the air was purged; there's still oil on both sides of the cylinder. Total volume doesn't change.
Lyle
