allen8106
Jul 30, 2015Explorer
golf_bears wrote:
OP, you list two problms in your post. One, the front landing cylinders are drifting. Two, a popping noise. Which is it or is it both? The correct solution is dependent on describing the problem correctly.
It's one and the same. The fluid is leaking off (drifting) which allows the coach to drop a bit which produces the popping sound.
About Fifth Wheel Group
