B_O__Plenty
Jul 30, 2015Explorer II
avvidclif1 wrote:Very common problem. More noticeable with temperature changes.allen8106 wrote:golf_bears wrote:
OP, you list two problms in your post. One, the front landing cylinders are drifting. Two, a popping noise. Which is it or is it both? The correct solution is dependent on describing the problem correctly.
It's one and the same. The fluid is leaking off (drifting) which allows the coach to drop a bit which produces the popping sound.
Why re-invent the wheel? It's a Lippert Level-Up system. They do that, some of them anyway, mine hasn't yet. There is a service bulletin out about it. Follow it and post back the results.
B.O.
About Fifth Wheel Group
