laknox
Oct 19, 2016Nomad
arglebargle, hydraulic rams or cylinders are pretty durn simple. Only 2 things can happen =inside= the cylinder. 1) the rubber piston seals fail, allowing oil to pass from one side to the other. 2) the cylinder wall can become worn or galled, which usually chews up the piston seals, though the wear on the cylinder walls can be so bad that the rubber seals just won't seal. If this happens, you gradually lose pressure on one side and the ram "relaxes" and either extends or retracts (depending on the direction of the external pressure on it). If the rod seal fails, you have a messy leak.
The other major source of internal leaks are the actuator valves. Here, the solenoids can fail or wear to the point where they don't completely move to open/close the valve. Other thing that happens is the valve seats can either wear or get trash in them, again causing a failure to seal. It doesn't take much of a leak, given that these systems run under a =lot= of pressure, to cause a cylinder to move. Bad (cheap) metal can even =erode= from the high pressures and cr@ppy castings can crack, again from the pressure. Had all that happen while on the farm, which is a much more extreme environment that RVing, for sure.
Lyle
Lyle
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
