Ajax106's avatar
Ajax106
I need your expertize...
Hi, this is my first post. And we just purchased our first camper/Toy Hauler this past Saturday. Brought it home with my 2012 Chevy Silverado 1500, and almost positive I need something bigger? The truck was really straining under the load!
We purchased a 2012 Dutchmen Rubicon. Here are the specs...
Length (ft/m) 24.67 / 7.5
Width (in/mm) 102 / 2590.8
Height (in/mm) 145 / 3683
Length (ft/ft) 24
Length (ft/in) 8
Dry Weight (lbs/kg) 5510 / 2499.3
Payload Capacity (lbs/kgs) 3490 / 1583.1
Hitch Weight (lbs/kgs) 861 / 390.5
Plus, we have two motorcycles that we want to bring along. Topped off they are a combined weight of 1460 lbs. I purchased the weight distribution system as well.
Looking at a 2011 Chevy Silverado 2500HD 4x4. Here are the specs for it...
Engine, Vortec 6.0L Variable Valve Timing V8 SFI (360 hp [268.4 kW] @ 5400 rpm, 380 lb-ft of torque [513.0 N-m] @ 4200 rpm) with (E63) fleetside pickup box; (322 hp [240.1 kW] @ 4400 rpm, 380 lb-ft of torque [513.0 N-m] @ 4200 rpm) with (ZW9) pickup box delete
Transmission, 6-speed automatic, heavy-duty, electronically controlled with overdrive and tow/haul mode (Requires (L96) Vortec 6.0L V8 SFI engine.)
Rear axle, 3.73 ratio
Can someone tell me if this truck is capable of towing this set up? The more I read, the more confused I become! Its all quite overwhelming to be honest!
Any advice you can give would be greatly appreciated!
Thanks in advance,
Chuck
