SkiSmuggs
Jan 20, 2014Explorer
Our 2012 HC RKS299 has an 8 Cu Foot fridge, battery disconnect, Hi gloss gel coat, toilet access with slides in, kitchen/fridge access with slides in, easy access to tank pulls, ext propane connect. Options were dual pane windows and 15 BTU AC which I believe also meant 50 Amp. I replaced the Load Range D with Maxxis LR-E and probably could have had the dealer do it as part of the deal. My recliners don't have to be moved to close the slides, but still need to be moved against the wall for lashing down, no big deal for us. Loaded, we have 1650 pin weight and 9500 gross. Since we pull with an F150, it should be no problem for a 250/2500 class.
About Fifth Wheel Group
19,033 PostsLatest Activity: Jan 22, 2026
