mayo30
Nov 20, 2013Explorer
Most of your noise will come from hard improperly installed water lines.Foam swim aide tube slit to fit over under and around lines will help a lot.Flexible inlet and outlet water line kit will help too,don't over tighten motor screw attaching screws.Mount the pump on a small 3/8" board and mount that board to floor with a foam 1/2" doughnuts from the swim aide between it and the floor.Flexible lines are available at dealers.A variable demand pump,though more costly are much quieter then the standard type.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
