cwill925
Nov 20, 2013Explorer
A noisy pump is usually a sign of air in the water line. Try this; turn the water pump on and let it reach sufficient pressure to shut off. One by one open each faucet, hot and cold, including, if applicable, the outside shower, washer connection and any other valve termination. You may have to let some of them run for a while depending on their distance from the pump. As the lines clear the air, the pump should settle down and get quieter.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
