Pauljdav
Nov 20, 2013Explorer
cwill925 wrote:
A noisy pump is usually a sign of air in the water line. Try this; turn the water pump on and let it reach sufficient pressure to shut off. One by one open each faucet, hot and cold, including, if applicable, the outside shower, washer connection and any other valve termination. You may have to let some of them run for a while depending on their distance from the pump. As the lines clear the air, the pump should settle down and get quieter.
X2. Mine is usually the shower line has air that needs to be bled off.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
