agesilaus
Nov 20, 2013Explorer III
mayo30 wrote:
Most of your noise will come from hard improperly installed water lines.Foam swim aide tube slit to fit over under and around lines will help a lot.Flexible inlet and outlet water line kit will help too,don't over tighten motor screw attaching screws.Mount the pump on a small 3/8" board and mount that board to floor with a foam 1/2" doughnuts from the swim aide between it and the floor.Flexible lines are available at dealers.A variable demand pump,though more costly are much quieter then the standard type.
Better than the swimming noodles is foam pipe insulation, it fits the pipe and comes with a sticky seal. Look at the pipes and estimate the diameter. If it's flexible tubing which it probably is, try one piece of 1/2 inch pipe insulation. It comes in 4 foot lengths. If that fits just get enough to do the job. It's cheap and any hardware store should carry it.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 25, 2026
