Shadowman00's avatar
Shadowman00
If the RV is Rockin
So I've come to the conclusion that I need to do something better to stabilize my RV when parked. The stabilizer jacks on our Weekend Warrior are "lacking" in my opinion. The are simply single legs that drop down on an angle. I can't see how they add a lot of stability, and from what I feel inside, they don't. It seems like if my 6 lb dog rolls over you can feel in in the RV?
Current set up. Our WW is a tongue pull so we have the tongue jack that I try to limit on the amount of extension that it has. I would rather add larger blocks of wood to provide a more stable support. We have the the X Chocks between the wheels. Since it is a triple axle I normally put one of the X Chocks between the front/middle tires on the left and rear/middle on the right. Then we have these single legged "stabilizer" jacks front and rear. When putting the stabilizers down, I usually don't put a lot of pressure on them, I wait till they make contact, then crank a few more times so that it actually lifts the RV 1/4 inch to know they are solid.
This weekend I noticed after 2 days, that the jacks were no longer touching the blocks, so I adjusted. As I was looking around, it seemed like most of the TT had scissor type stabilizer jacks. From a visual perspective they seemed a little beefier than what I have?
I'm curious, what others are doing to try to take the rockin out of their set up. Would it be worth cutting the smaller stabilizers off and installing scissor jacks, or do I go with Hydrolics? How much weight should these "stabilizers" be supporting?Believe, me I don't mind a little movement, as I understand it has a suspension under it, but I feel like I'm getting an excessive amount of movement when simply turning over in bed or walking around?
Thanks in advance for any suggestions.
  • When we had a TT it came with 4 jack stands...the type used on mobile homes.
    I would get the trailer level side to side using blocks under the tires. Then unhitch and level front to back using the tongue jack. I would then lower the front until it was just unlevel and place the rear jack stands under the frame and adjust them until they were tight against the frame.
    Next raise the front of the TT to level and place the front jack stands under the frame. Tighten them up against the frame and raise the tongue jack just a little to put more weight on the front jack stands.
    The jack stands would support the weight of the TT and eliminate any bounce from the springs or tires. The TT was rock solid.
    You can buy these type of jack stand online or at some of the independant RV Supply Stores.
    Here's one supplier http://www.bandrstamping.com/LEVELING_JACKS.html
  • RoyB's avatar
    RoyB
    Explorer III
    Don't know if your RV is a fifth wheel or not but I added the tripod to my 5th wheel pin box and it really helped.
    They also make some braces that go from one side to the other that is suppose to help too...
    I too crank down my bars until alot of pressure is on them. I use a good solid 2x8 or 2x12 under the jacks also...
    Roy Ken
