KKELLER14K
Dec 22, 2016Explorer II
OK, I'm shaking my head but I have to ask. Your going to fix it, de- winterize it, cross your fingers it doesn't leak anywhere else and then bring it back. What happens then? Will you be using it anytime after? Take it straight to the dealer? You SHOULD most defiantly take it straight back there in my opinion. So say you fixed it, you bring it straight back to them and the dealer pats you on the back and says thanks for fixing it how was the trip?.. or they want to keep it for inspection? Your going to have to figure out what you are entitled to for their mistake. At this point you still do not know if it has any internal damage. Not sure what your weather will be when you get back, but if it gets below freezing again, your going to either have to keep heat in it or winterize it again if need be. If your not using it and it is going to sit at the dealers, make sure they take precautions and winterize it then and there. Otherwise this rig is yours now and you have to take the responsibility to maintain its integrity. If you do fix it, they don't keep it because they looked it over real quick like, your not using it for a spell, I still would make the dealer winterize it again for free. Where will you get the parts? When and where will you fix it? Are you billing them for the labor to install it?.. LOL! see that was funny. Take pictures...to bad you don't have this in writing.. POSIBBLY their fault?? They are not going to easily admit they crashed the party. See where this COULD go?? Document everything. If you winterize because you had to keep your receipts and take pictures of you doing it. Food for thought. Have a good holiday and hope your trip goes well.
About Fifth Wheel Group
19,032 PostsLatest Activity: Jan 04, 2026
