stripit
May 23, 2013Explorer
If you were able to take the rig back to the CAT scales and weigh each axle so you knew what that axle was according to them, then tried your method again to see if your system is close or way off. As I think about this, there is going to be weight transfer since only one wheel is off the ground a bit with your scale. I don't think your going to be real accurate your way.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
