Second_Chance
Nov 24, 2017Explorer II
You don't say what the construction of the unit is - wood frame with aluminum siding or aluminum frame with fiberglass. If a wood frame, a "soft spot" usually indicates rot from water incursion and entails MUCH more than just repairing a small spot. To do it right, the inner and/or out panel(s) need to be removed and the framing replaced - and figuring out how the water got in in the first place.
Rob
Rob
About Fifth Wheel Group
