KnowNuthin's avatar
KnowNuthin
Sandwich repair (interior wall)
Just finished pealing the wall paper and what was left of the plywood off the bedroom wall... I was expecting some 'studs' behind the wall to fasten a new wall panel to... there is one vertical stud at the rear corner but that's all the studs I found...
The disintegrated plywood section is from ceiling to floor--about three feet wide--and, yes, the leak in the roof has been fixed (new roof)
What we have looks like a 'sandwich'... fiberglass exterior-foam board insulation-plywood interior-vinyl wall paper...
I got all the plywood off the interior up to the point where there's a very thin layer of the old plywood still glued to the foam board insulation...
Questions:
Do I 'sand' off the old plywood or can I glue a replacement plywood section over the old plywood?
I've narrowed my replacement panels down to two choices--a Luan plywood (from Home Depot) covered with... well, I'm not quite sure what to cover it with (see question below)... the second choice is a decorative hardboard panel from Lowes ( Lowes Paneling ...it's got 'wallpaper' attached to it already so once I glue this panel up I'd be done)
If'n I sand off the plywood (down to foam board) what type of glue would hold the plywood/foam together without 'eating' the foam?
Any suggestions on a complimentary/contrasting wall covering for when I get the new plywood up? (I kinda doubt I'll be able to find 'matching' wallpaper)
