Dayle1
Nov 24, 2017Explorer II
How big is 'small'? Cut the minimum opening required to check for damage to the backside of the exterior skin and with a mirror check the backside of the interior panel around the opening. What you find will dictate repairs needed. Then if the opening is small enough, then hide it with a fake outlet or battery operated motion activated nightlight. If it is larger, make a fake access panel that you can always use to check for repeat leaks.
About Fifth Wheel Group
