bomo3's avatar
bomo3
Explorer II
Jun 30, 2025
Insight re: purchase
Hello, seeking insight:  we are considering an opportunity to purchase an "older" 5th wheel - approx 13-14 yrs old. Not used for over the road travel, rather a seasonal site. Our intended use would be similar in same location. Seeing lifespan estimates about 5th wheels and trailers in general online, feeling a bit nervous about a big investment ($18k), but it does on the whole seems clean, very well kept and maintained, and like it is a decent deal vs what we are seeing for the range on newer models.  Was hoping for #1: any considerations and thoughts about buying a used model in this age bracket - does it matter if it hasn't been on the road (surely tires are shot just from sitting).  Amd #2: Would also appreciate specific things to look at and watch out for when considering purchase and going to look it over in person.
Thanks in advance!
  • The roof definitely looks dirty and moldy. But just dirt is not a real detractor. It's all the sealants around the penetrations that you need to look at. From what I can see there is no current cracking in the pictures so it is very possible that the owner was being honest about the roof being regularly inspected and repaired as needed. Of course the hardest thing to see is the roof sides where the roofing go behind some trim pieces.
  • An update to my original post: We did go and took a look a few weeks ago when this opportunity had dropped in my lap. I had also managed to track down an inspector willing to take a look (after 4 ppl!!) if we decided to proceed, but ultimately, we opted not to move forward with this rig given our concerns re: the age/roof etc..and also after accepting a realistic view of how often we could actually use it in the immediate future. With that said - I am curious for thoughts from those here with more familiarity about these rigs. We showed pics to friends with some RV history, and they cringed when seeing this roof (lots of tree canopy/shade, has been campground kept since 2011, told roof has been religiously sealed/checked 2x each year, body gets washed, etc).  I know an inspection would've determined more about the condition of the roof if we went through with it - but I remain curious of the expectation of whether this is what a 14 yr old RV roof would "normally" look like based on age & location, or perhaps this is just best used as the perfect Wet & Forget "before" photo....??
    • way2roll's avatar
      way2roll
      Navigator III
      That roof is disgusting and water is laying in the slide topper. You can choose to believe if the roof has been sealed annually but I can tell you that roof has not been cleaned in a long time. In order to properly inspect and seal a roof it must be cleaned. If they put new caulk on a dirty roof, well, that's not good. At a minimum these pictures tell me all I need to know; this RV is not properly being taken care of. This is what you can see. What can't you see? Too many used RVs out there not to pick one that's been meticulously taken care of.
      • Grit_dog's avatar
        Grit_dog
        Navigator II
        100% correct analysis by way2roll.
        I know you’re passing on not only the rv but the whole concept but think about what he said and what I said earlier.
        piss poor exterior cleaning and maintenance combined with presumably the equivalent of 3-4 years of full time use. There are just too many older used RVs for sale that have actually been cared for with actual light use to give even a glance at someone’s rv summer cabin for the last 10+ years.
        Thats alot of farts in the mattresses. Lol
  • Could be very reliable if it was well kept, you can get a feel for that if the owner is forthright about what they’ve fixed and maintained.
    14 years outside, the roof could be trashed, or 14 years stored under cover and out a couple months in the summers is a different scenario.
    As you know there’s kinda 2 separate components, in general. The house and the chassis.
    In this case the house is presumably well used. (A dozen years as a “summer cabin”). Could be super easy use if it was a couple old people who spent a month a year there or could be worn the f out if it was a family with 4 kids and mooching cousins who spent all summer every summer in it.
    The chassis should be like new save for a little maintenance but that’s of little value to you if you’re just parking it too.
    Personally I’d be targeting one miles on it and light use on the house rather than the other way around.
    But it’s impossible from your description to tell if this trailer is actually a good value.
  • look up mobile rv techs in your area, when buying a older rv it is well worth the couple hours of labour you might have to pay him to go look at it with you.  he will know where to look to find the issues and not be blinded by excitement like a purchaser will be.  he can also give you an estimate of what it would cost to fix the issues or if they are even worth fixing, and if you should buy it or run away.
  • Condition is key with older Rv's. No one on here can offer an armchair diagnosis of an old RV and all it's systems and structure especially with no details about make model or condition. Best advice - get a qualified RV inspector and have a thorough and documented inspection before you make any offer. Then you'll know what you're dealing with.
    • bomo3's avatar
      bomo3
      Explorer II
      Thank you, please know I didn't post expecting an armchair diagnosis from anyone - just trying to do my due diligence for things to consider or look out for when contemplating used/older units from folks who know more than I do. I appreciate the response re: seeking out a separate RV inspector to include in this process.
      • Grit_dog's avatar
        Grit_dog
        Navigator II
        There are SOOO many used RVs that have gotten little use, that are really not worth “much” more than ones that were used regularly and used a lot, that it doesn’t compute with me to get one that’s been lived in for effectively “x” number of years vs one the same age stored under a carport and used a few weeks a year.
        Since you don’t plan on towing it around it may seem convenient to buy the one that only need moved 200 yds to its new home. But can predict that it will likely have more wear n tear from use. Big ones being exterior/roof assuming it’s been left outdoors uncovered and the appliances. Don’t know for sure but 14 years on a fridge, AC, water pump, etc that are all used alot seems like the life cycle has been largely used up. Whereas the lightly used and covered RV will have more lifecycle left in these and other components.
        Especially now with the COVID buyers being a couple years into dumping their overpriced seemed good at the time decisions.
