Sandia_Man
Sep 05, 2014Explorer II
Most Onan gennies installed on fifth wheels are vented through the floor but they are typically 5.5 Onan units. We have a TH with a 4K Onan installed and it is vented through the door, can't help on where to store gas as our rig has a 25 gallon tank for genny fuel.
Obviously gas consumption on such a large genny will be significant, but I would imagine running both ACs will require roughly 5K watts and consume about a gallon an hour. Our 4K unit uses about a 1/2 gallon depending on load.
Can't help you on installation as ours was installed at factory, but if you got a good deal on your Onan and you already have the prep done from the factory, it might be a good idea to have it professionally installed to eliminate any guesswork. Our Onan utilizes our house battery bank for starting. Good luck and enjoy the convenience of an onboard genny.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
