katysdad
Mar 27, 2015Explorer
Relatively easy install. You will need the fishing wires to pull the bolts through the frame. Make sure you use the listed 17/32 drill bit. that is key in getting the bolts to grip the hole in the frame when you tighten them up.
I have also used the no drill kits that clamp to the frame. They also work well.
Be aware of wires and brake lines on the drivers side when drilling the frame rails.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
