MeandMyLabs
Dec 06, 2013Explorer
I think many on this thread are not distinguishing the difference between the generator engine and the electrical generator itself. They are two completely different systems designed to work together and generate electricity.
The engine, if it runs on gasoline, should be run monthly to prevent carburetor build up (gumming) but if LP maybe not so critical.
The generator, consists of windings and magnets which are constructed the same whether no matter what fuel is used for the generator. These windings and magnets will get moisture in them over time from the natural humidity in the air and condensation. If they are not exercised, over time, the windings and magnets will lose efficiency and eventually become inoperable. Exercising the generator monthly will help to prevent this situation by simply drying these windings from use.
Yes, some will say they have never had a problem but if you really want your generator lifespan to be longer, monthly exercise is best.
About Fifth Wheel Group
19,040 PostsLatest Activity: May 21, 2026
