Ed9824v
Aug 09, 2013Explorer
Peg Leg wrote:
I welded a square tube to each frame rail. The tube has a hole in the center like a receiver that I use to bolt two different rear accessories. One has a 2" ball for pulling my alum fishing boat. The second is a tray about 18" wide that I can haul firewood, burn barrel or my generator.
this is what I built for my rear rack my pull my offroad baja soon. I used grade 8 bolt nuts and washers.used grade 8 nut bolts and washers.
then I had to cut through the fiberglassthen I plasma cut a square opening to put the receiver hitch in and fully welded that up
About Fifth Wheel Group
