- hvacExplorerIn a nutshell, although battleship reliable, and she has approx 37k miles in just 3 short years,the ATC is not an extreme cold weather coach. We find as it approaches below 30, then its time to move further south. Currently in desert hot springs. If you go colder then I would suggest investigating with the factory on what they offer as options.
- naytherExplorer
Tyler0215 wrote:
You need to ask WHERE the extra insulation is. The roof and walls are only so thick, so, unless they upgrade the quality of the insulation, you won't gain any benefit there.
Extra insulation in the floor and for the tanks is a different story. Ask a lot of questions from the manufacturer, not the dealer, before you pay for something you may not need.
if they use higher "K" value insulation it would be better, should not be a big add. If they're adding underbelly insulation as someone suggested that would be more $$ - Tyler0215ExplorerYou need to ask WHERE the extra insulation is. The roof and walls are only so thick, so, unless they upgrade the quality of the insulation, you won't gain any benefit there.
Extra insulation in the floor and for the tanks is a different story. Ask a lot of questions from the manufacturer, not the dealer, before you pay for something you may not need. - cavieExplorerYou won't get anything EXTRA in the walls or roof. You will get a plastic cover for the underbelly.
- LwiddisNomad IIIExtra insulation is a good choice.
- Johno02ExplorerIf buying new, I would get it. Will help with both heating and cooling. Usual RV walls and insulation are much like cardboard.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
