otrfun's avatar
otrfun
Explorer II
Nov 19, 2016
Inter-State Travel with RV (TV/Trailer) with GCWR >26k lbs.
Anyone aware of a reciprocity agreement between states that may regulate the following issue?
Each state has its own laws regulating licensing for privately-owned, recreational vehicles. When the GCWR for the tow vehicle and trailer exceed 26k lbs. special licensing is required in many states. Some states, like CA and TX, require their residents to have a non-commercial (state-issued, non-DOT) Class A/B/C license when towing RV's with higher GVWR/GCWR'S; whereas states like FL and AZ have no weight restrictions in terms of licensing for RV's. Residents in FL and AZ may drive an RV (TV and trailer) with any GCWR with only a standard Class D operator's license.
Question:
Can a legally licensed driver from FL or AZ operating an RV (TV and trailer) with an GCWR greater than 26k lbs. legally drive through CA and TX?
Thanks!
Yes, I'm aware a DOT CDL (commercial) Class A license would negate this entire issue.
  • CumminsDriver wrote:
    California requires the Non Commercial A for 5th Wheels over 15k GVWR and Travel Trailers over 10k GVWR for Ca residents. My last truck was 10k GVWR and my 5th Wheel is 15,700 GVWR. Under 26k but still required the Non Commercial A License. You are only required to be legally licensed for your home state.
    Rich
    Thanks for clarifying CA's Class A license requirements, Rich. If I understand you correctly, CA requires a state-issued, Class A license if the GVWR of a 5th wheel exceeds 15k, without regard to the TV's GVWR or the rig's overall GCWR?
    Rich
    THat is my understanding as well. However MD has the same requirement but the rule is seldom enforced. Many Marylanders do not have the proper endorsements. Therefore they are not legal in their own state and would not be legal in CA either
  • California requires the Non Commercial A for 5th Wheels over 15k GVWR and Travel Trailers over 10k GVWR for Ca residents. My last truck was 10k GVWR and my 5th Wheel is 15,700 GVWR. Under 26k but still required the Non Commercial A License. You are only required to be legally licensed for your home state.
    Rich
