azbohunter wrote:
Mike134 wrote:
Replace all the splices, wiring never fails in the middle, always at the connections.
I have checked everything visible and I can't see anything that looks like it would be a problem. I have heard of insulation wearing off inside the axles over time. It might not be my problem but I think that I will pull new wires thru and then I will know.
Replacing the wiring will give you peace of mind that the wires are are good and you'll need to replace all the connections for the new wires so in the end your problem will be fixed.
safe travels.
