CVD
Dec 26, 2017Explorer
Intermittent Warning Sound, Stops w Brake
Just picked up RV after week in storage, chassis is 1998 Freightliner XC (air brakes). I now have a high pitched warning sound coming from the dash (like low air pressure warning), that is intermittent (sometimes on, sometimes off). There is no warning light accompanying the sound. I can be parked or moving and it may come on. I have narrowed the conditions a little:
1) The sound always stops when I apply either brake (parking brake or peddle brake).
2) When sitting at idle, with parking brake active – no sound (No sound once air pressure is up, otherwise I get the expected low pressure sound and light). If I release parking brake (level ground of course) it might make the sound. If I press brake peddle – no sound. When I let up brake peddle – always makes sound (even if it wasn’t making the sound beforehand).
3) When sitting at idle with no brake and the warning sound “on”, I can eliminate the sound by reving the engine up to 1,000 – 1,200 rpm. When the revs drop back to idle the sound comes back. Again, if I put the peddle brake or parking brake on – sound goes away.
Suggestions?
Suggestions?
