Sheepdog78 wrote:
I’m looking at a Firman WH02942 dual fuel inverter 3200/2900 watt generator for use with a 50 amp 5er. I’m looking for just enough power to run 1 ac and some lights, yet be light enough to easily move. Anyone have any experience with Firman?
FYI: "Normally" EVERYTHING "generator/s" will be found in the TECH ISSUES forum - (also consider the search feature - both the most recent 12 months and older than 12).
However generator threads can be found in various other forums (as this one is) whether Toy Haulers, Travel Trailers, the several MH forums, etc. (so if you do a search - don't limit it to any one forum).
Lastly -as above- there is a thread currently running in the General RV Issues - regarding a FIRMAN
RECALL.See thread by "2112" started 5-23-19. The model is not the one you indicated, but should you - or someone else - change your preference, it's worth reading.
Also - (assuming it's correct) it should not be a problem getting a "fixit" or replacement by Firman or Costco - just your time and effort.
:C
