RockinfigsExplorerDec 29, 2018Inverter off while running the generator?My hauler has one lithium battery, 1800 inverter n a 5500 onan gen.. When using the gen.. Do I need to turn off the inverter or does it matter if it's on.
2oldmanExplorer IIDec 30, 2018Thanks. Your inverter manual should tell you if it has a TS. Sounds like it does.
Related ContentInverter Bad?Running Inverter Generator Safely From PickupInverter installGenerator will not run installedInverter Generator
