How do you test an inverter to see if it's bad??? What are some things to look for? Electric bill is horrendous. Everything seems to check out ok in the camper itself.
Yep, probably need to look at your electric usage if the bill is horrendous. Mine is $40/mth without using AC, and running frig and WH on propane. Next door neighbors (in similar size 5er) run $100/mth running the AC a lot and all appliances on electric.
