4x4FF
May 04, 2015Explorer
Inverter size
Hi all,
I just got my new residential fridge installed in my 5er. It is a whirlpool WRT111 and it is 10.7 cu ft. I love it so far. With the unit being at ambient temperature (and never having been ran I might add) I plugged it into a kill a watt meter for start up. After watching it for some time the absolute highest wattage I observed was 120 and that was briefly. Normally it ran between 80 and 90 watts while running. I know that the kill a watt isn't sensitive enough to show the peak wattage at compressor startup so that number may be a bit higher.
My question is what size inverter would you guys recommend?
Before we begin, I just want to say I would love to get a 5000 watt inverter and run with 8 6v batteries....but.....That can't happen right now. I have NO intention of boondocking. I only want the inverter to power the fridge while traveling and maybe during campground power outages. I will be running off of 2 6v interstate batteries. What size inverter can I get by with? I am looking at a Xantrex ProWatt in either the 600 or 1000 watt output. Money matters so if I can save $100 by going with the 600 that is fine with me. If you guys can recommend a good inverter other than the Xantrex in the $100 to $250 price range I am all ears. I just want a PSW inverter. I just want to make sure I have enough to power the fridge while I am on the road. I also purchased the Xantrex Transfer relay. What do you think or what other information can I provide?
Thanks,
Steve
Thanks,
Steve
