bad99ram wrote:
I am having the following problems with my inverter for the fridge. When I am hooked up to my truck ready to leave I turn the inverter on. When I stop in a rest area I check it and it is not working. I have tried to turn it off then on again and it will fail to start up. I have to turn it off, unplug from the truck, replug it back in, then turn it back on , at this point it starts right back up again . At the next rest stop the whole process needs to be repeated. I have checked the battery in the unit and it has a full charge. Does anyone have any troubleshooting ideas I could try prior to bringing it in? Good news its still under warranty.
If your fridge runs on gas and electric just set it to auto and it will run on propane when electric is not available.
