45Ricochet
Jul 22, 2013Explorer
You already have the cream of the crop in the above posts. But what Gemstone told you is correct. That little small Cougar might very well share some components.
Although they are no longer made you might add a Grand Teton to your list. They will also require a DRW tow vehicle in most cases as they are heavy. Most will have three axles which lightens up the pin weight.
Most any 2011 trucks will pull them without a problem. In fact the new Dodge Ram is rated to combo out at 37k lbs which is a trailer tow rating weight of ~ 28000 lbs. That there is bigger than any fiver I've seen.
Good luck and drive on the right side of the road :B
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
