laknox
Jan 10, 2013Nomad
N-Trouble wrote:
I've read several posts now stating that GM trucks have a longer distance between the back of the cab and the rear axle vs Ford or Dodge. Is there anyone out there towing with a late model GM short bed that does not use a slider and can still hit 90* without worry of hitting the back of the cab? I assume each trailer and king pin length combination will also factor into this.
Will also depend on if the TV is 4x4 or 4x2. A 4x4 just can't turn as short as a 4x2, all else being equal. My '02 4x4 D'max can NOT hit the trailer at full lock in both directions when going forward. ALL will hit in reverse...just some sooner than others. YMMV...
Lyle
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
