NMDriver
Mar 20, 2015Explorer
... that the extended pin box does not.
I think you will find the pin extension does the same thing as the slider. It moves the "centerline" (front edge of the 5er) back from the cab. Now whether or not it is enough for your particular rig depends.
Easy test is to take a 2"x4"x4' and put it over the pin to see where the edge would be if you turn. Actual width is less than 8ft but you can get a good idea with that test.
About Fifth Wheel Group
