valhalla360
Mar 21, 2015Navigator
C-Bears wrote:valhalla360 wrote:
If he has the same truck ask him to hook it up and see how sharp he can turn.
Actually, I would have posted this same thing a year or so ago. But now I have to say that is really bad advise.
I got a slider with my "short" bed because a RV mechanic told me to. Then after visiting over 26 states and never using it I felt I had wasted my money.
Until backing into a site in Florida this December. I had it cranked pretty far, but not nearly as far as I have had it in the past. A guy in another site yelled at me to watch my cab. I stopped, got out and looked, my FW was actually touching the corner of my cab!
The ground in the site was a little soft and caused my FW to lean a little too far into my cut. It was hard to see the lean from the driver's seat. So, you may be able to cut it really hard around and never touch as long as your TV and FW are pretty level, but if you FW gets to leaning you will wish you had a slider!
The point is if it's the same truck he can see how far it will turn. If he can turn 80-90 degrees, it's a non-issue. If he can only turn 45 degrees, he needs a slider.
In between it's his comfort level.
About Fifth Wheel Group
