hoopers
Oct 04, 2013Explorer
LostinAZ wrote:
I would strongly recommend that you do a energy loss analysis on the total RV. If the RV has multiple slides I suspect you will find much more energy loss associated with the slides than the single pane windows. Also verify that they are truly sealed double pane windows. Also consider the extra weight and added initial cost these windows will add to the RV. Also consider the amount of time you will spend in the RV each year and what the temperatures will be when you are in the RV and then calculate the savings vs the initial costs. Very few RV double pane windows are of the quality that are installed in stick homes.
good point
About Fifth Wheel Group
19,043 PostsLatest Activity: Sep 10, 2026
