Sea_Six's avatar
Sea_Six
Is it possible to re-mount the tv batwing antenna
So as to move the dead spot to a different location? I'm talking about the small portion of the arc where it isn't possible to point the antenna. When I park the rig at my house the dead spot is precisely where the antenna needs to be pointed. Rather than put up a new antenna I'd rather just turn the base mount.
I do realize the antenna would no longer be pointed towards the rear when it's all the way down on the roof. I'd like to turn it around 45° from where it's mounted now.
How is it mounted? How would I go about doing this?
  • Before I go to all the trouble of removing the entire antenna by the mount, I just thought of something.
    Is it possible to remount the antenna head by itself, without removing the base, and point it 180 degrees in the opposite direction? In other words, mount the antenna head so that it's on the opposite side from where it's mounted on the mast.
  • sdetweil wrote:
    I don't think so.. depends on all the other stuff on the roof that it fits around..
    here is someone elses install of one of these, cause it gives good pictures. batwing antenna install
    Awesome. That's what I needed to see! Saves me from tearing off the antenna just to see how it's mounted. I think I can do it without too much trouble.
  • Looks like you have to unscrew a bunch of screws into the roof, rotate, reseal and rescrew.. it looks like the mount is not round, but pear shaped, so there may be exposed screw holes when u turn it.
    I think the inside base (with the pointer) is aligned with the flange of the top piece.
    based on the pics in the link I posted.. if yours is a Winegard.
  • There is nothing in the way for where I want to lie it down.
    I just want to know what is involved in remounting it.
  • I don't think so.. depends on all the other stuff on the roof that it fits around..
