topjimmy wrote:
For one thing your Oakmount does NOT weight 15.8K DRY my 2015 39 ft Montana is heavier than your Oakmount at 13.2K Dry you are confused with the GVWR of you Oakmount, anyway get airbags and that will get it the level you want and that shocks me your Ford Dually is sagging so badly my 2007 GMC 3500 Dually does not sag at all with a pin of #3800 lbs so I do not get why you are sagging so bad in the picture
Every F450 and 350 pulling a DRV that I've seen has bags. I'm betting the 17's won't be that way.
