aviator41 wrote:
topjimmy wrote:
For one thing your Oakmount does NOT weight 15.8K DRY my 2015 39 ft Montana is heavier than your Oakmount at 13.2K Dry you are confused with the GVWR of you Oakmount, anyway get airbags and that will get it the level you want and that shocks me your Ford Dually is sagging so badly my 2007 GMC 3500 Dually does not sag at all with a pin of #3800 lbs so I do not get why you are sagging so bad in the picture
You are right. my bad. the dry weight is 13576 lbs (plus our added extras).
GVRW is 15.5k lbs
Be gentle guys, I'm still learning here. I'm TRYING to do things right and I have yet to master all the lingo that comes with my very first RV.
If you are not full forward with the hitch do so. That means the head side supports will have the straight edge forward.
Won't make as much difference as some think. I add about 150# or so to the front with 5,600# pin weight.
